Wingnutt
Jan 07, 2012Aspirant
Turn off blue dome light!?
I just purchased a WNDR3400 and right out of the box the stupid blue dome light is ON. I read tapping it will turn it off, this does not work, tapping it makes it blink for about two minutes, then ...
nanobot
Oct 10, 2012Aspirant
nanobot wrote: Ok, after posting this message, the repeat blinking pattern would start every 10 minutes or so and then stop. I went to the router manager > Advanced > Wireless Settings and under WPS Settings, placed a check in the box labeled Disable Router's PIN. (note, no other changes were made). This effectively disabled WPS mode, which I do not use. The router has not lit up since. If you use WPS, you might need to stick with the old firmware.
~~~~nanobot
Update 10/10/2012:
After about a week, the flashing started up again. Downgraded the firmware to v.38
