Wingnutt
Jan 07, 2012Aspirant
Turn off blue dome light!?
I just purchased a WNDR3400 and right out of the box the stupid blue dome light is ON. I read tapping it will turn it off, this does not work, tapping it makes it blink for about two minutes, then ...
dborja
Oct 14, 2012Aspirant
nanobot wrote: I had this same problem. After several months after upgrading to 1.00.50, my router suddenly started doing exactly as was described: led antenna indicators flashed. When I depressed the dome light, it blinked repeatedly for a few minutes and did not shut off.
At the suggestion of scvenne, I downdraged to 1.00.38. I successfully shut off the dome lights. Then, I upgraded back to 1.00.50 and the lights stayed off. So if you want the latest firmware and to have the lights off, you will have to downgrade first and then re-upgrade. Note that for this to work, I had to downgrade first. Simply re-flashing the 1.00.50 firmware on top of itself did not work.
I did not notice a change in speed as Borthalomew noted upon downgrading or re-upgrading. I will repost if the lights come on again. Ok, now I will get back to life. Thanks for the thread, all.
~~~~nanobot
Thanks nanobot! This worked like a charm! I was about to go with the duct tape route but I didn't like how tacky that solution was (pun intended). :p
