Wingnutt
Jan 07, 2012Aspirant
Turn off blue dome light!?
I just purchased a WNDR3400 and right out of the box the stupid blue dome light is ON. I read tapping it will turn it off, this does not work, tapping it makes it blink for about two minutes, then ...
mailiang
Dec 05, 2012Aspirant
To disable the WPS when this issue occurs, disable the SSID. Then reboot your computer. You will now have to manually input your id and password to access your network. Open your browser and router utility (Netgear Genie) and enable the SSID again. Your WPS willl remain off unless you turn it back on using the WPS wizard set up utility. You can now push on the router's WPS button and turn the light on or off.
Ian ;)
Ian ;)
