repap
Dec 10, 2012Aspirant
Two N-wireless routers in series
I have the following two wireless routers. The 3300 is the base unit with the 3500 located at a distance as remote unit. Everything works fine, accept that the remote unit will hang on an IP address...
repap
Cables run from cable modem to wan on 3300, then 3300 lan to 3500 lan via netgear powerline adapter.
