mrr42's avatar
mrr42
unable to access login page for extender
I misplaced the admin password for this network extender (model EX6150) and needed to recongifure a few things and upgrade the firmware so I did a factory reset thinking I could simply start over.  I was able to get the extender to connect to my router using WPS and basic connectivity seems to be working fine.  I do want to change some of the security settings, check the firmware levels and customize things to my needs though.
After some intense investigation using the web interface (mywifiext.* and 192.168.0.250 didn't work), I was able to determine the IP address of my extender and was able to bring up the "new extender setup" page.  I tried filling out the page again (a number of times) but I don't seem to be able to get by that screen.  I then tried to guess at the admin login page URL (unsuccessfully) to try to circumvent this obstruction but I guess I am not clever enough to guess it.  I think if I could get the URL to enter into the browser to access the admin login page I might be able to use the default credentials to login and resollve the issue but as yet I have not been able to guess it.
Any help/suggestions are appreciated.
Thanks,
  • I was FINALLY able to get this resolved.  I needed to purchase an RJ45 connector (I have a MacBook Pro with only USB-C ports), hook it up to the EX6150 while I reset to factory defaults and eventually after a little poking I go to the logon screen.  Persistance paid off.....
    • Christian_R's avatar
      Christian_R
      NETGEAR Employee Retired
      Hello mrr42,
      Thanks for providing an update to the post as it may help others in the future.
      Christian
