thingtwo
Oct 23, 2020Initiate
Unable to configure EX3700 to use WPA2-AES
Hello, I followed the instruction manual, but couldn't figure out one seemingly simple step. I've connected my router to the extended via WPS. I can connect via 2.4 Ghz and 5 Ghz. The extender is...
Oct 23, 2020Guru - Experienced User
What method is the router using? If setup using wps, it should use the same encryption the router uses.
thingtwo
Oct 24, 2020Initiate
Thanks for checking. That would be logical. However, my router is configured to use WPA2-PSK [AES]. The extender is on the older standard. My devices throw a security warning when connected to the extender. Router has always been fine and no security warnings.
I went to mywifiext . net, and I'd think the configuration should be buried somewhere in the menus, but I didn't see it. Do you know how to get to the setting in the menu?
- plemansOct 24, 2020Guru - Experienced User
What device is giving you a security warning?
In the device settings for the extender, what does it show for the extender security method?
https://www.howtogeek.com/204697/wi-fi-security-should-you-use-wpa2-aes-wpa2-tkip-or-both/
