Dotdotdot_
Jun 24, 2022Follower
Unable to connect Netgear EX6120 to Virgin Hub via Ethernet.
Hello, I want to set up my Netgear EX6120 extender. I turned it on and plugged the Ethernet cable into the extender. I then ran the cable to my Virgin Hub 4. But I can't connect it to my router. The ...
Jun 24, 2022Guru - Experienced User
when hardwired in, the EX6120 would need to be setup in access point mode and not extender mode.
Have you ran setup in access point mode?
