taniala20
Sep 07, 2020Tutor
Unable to connect second extender Powerline WiFi 1000 - encryption key does not match
I'll try to keep this simple. I purchased 2 PowerLINE WiFi 100 Essentials Edition (model PLW1010v2), as I need to extend my network in two areas. I plugged the first one in, set it up, and it's worki...
Sep 08, 2020Guru - Experienced User
- taniala20Sep 08, 2020Tutor
This worked. I used the first WiFi adapter to set up the 2nd one and now have connectivity. So that is solved.
But I now have a different problem. I only have two outlets in the space I need to use it. The preferred outlet location does not seem to work. It connects, but the pick a plug light is either red or goes off completely, dropping the connection. (I imagine this is why I was having trouble connecting earlier). I then tried the other outlet (which has a GFI so I thought it may not work). It works great. However, it forces me to move all my other devices to the other outlet, with wires running across the room- not at all ideal. Sounds like an electrical issue at this point. Any advice?
- plemansSep 08, 2020Guru - Experienced User
it could be interference. You can try unplugging outlets in the vacinity of the non-working outlet. Maybe one of them is going bad or injecting interference.
You can also check the breaker. Some have issues with arc fault breakers.
I'll check out your suggestions. Much appreciated.
