ahhorner
Apr 27, 2025Aspirant
Unable to connect to AC750 extender
 I switch service providers, so I no longer need the router that I was using. I'm trying to reset my range extender. I tried using the website, but it says the site can't be reach. I tried using the a...
- Apr 29, 2025I left it plugged into the wall for a couple of days and used a different computer to do the set up on, so it's good now. Thanks for the reply.
Apr 29, 2025Guru - Experienced User
so if its still failing, screensnips/videos of where its failing int he process help us to understand whats going on. Or a more thorough of an explanation.
ahhorner
Apr 29, 2025Aspirant
- plemansApr 29, 2025Guru - Experienced User
Glad you got it working! You might mark it solved so others aren't still trying to fix it.
- ahhornerApr 29, 2025AspirantI was looking earlier for something to close it, but I didn't see anything, figured it was because I was on my phone. I accepted one of the replies as a solution, but I'll check again when I get home.
