sjnorcal18
Nov 22, 2019Aspirant
Unable to connect to mywifiext.net when I'm connect to extender
Hello, I am unable to access mywifiext.net when Im connected to my wifi extender. It takes me to this Netgear landing page that says "You are not connected to your extender's WiFi network." I am ...
Nov 22, 2019Guru - Experienced User
Have you tried connecting a device to the ethernet port to see if its possible to access that way?
Or possibly to try a different web browser.
sjnorcal18
Nov 29, 2019Aspirant
Yes, I tried with ethernet and mutiple browers and still recieived the same error.
- plemansNov 30, 2019Guru - Experienced User
Try shutting off your router. Just leave the extender on. Maybe the router is causing an issue with accessing the extender.
What firmware is on the extender?
Another option is to look in your router's attached devices page (or the equivelent for your router) for the IP address of the extender. Then use this address to access the extender.
What router are you using?
