patsfans_1994
Oct 16, 2021Follower
Unable to join the network "NETGEAR_EXT" because there is no option seeing my wifi manager
I am unsure of the firmware version because I cannot get the Extender to communicate with my Router (Sagemcom). My router is WPS compatible, but when I try to connect my Extender to the router it giv...
Oct 16, 2021Guru - Experienced User
1. what extender do you have?
2. what satemcom router is it (some have issues with extenders)?
3. did you click on the wps button? A mesh extender that is setup with wps will use the same ssid as the router.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
