JohnT41
Jun 11, 2024Aspirant
Unable to log into access Point AX 1800
I set up my access point from cat 6 line in a bedroom. Now I moved it to the ceiling in another room(another cat 6 connection) Now I'm unable to log on with the IP address or APLOGIN.NET. The passwor...
Jun 11, 2024Guru - Experienced User
Log into your primary router and check to see if it didn't assign it a different IP address.
The primary router assigns that and it might not have used the original
