JohnT41
Jun 11, 2024Aspirant
Unable to log into access Point AX 1800
I set up my access point from cat 6 line in a bedroom. Now I moved it to the ceiling in another room(another cat 6 connection) Now I'm unable to log on with the IP address or APLOGIN.NET. The passwor...
danielbryant23
Jul 01, 2024Aspirant
It sounds like your access point might have a different IP address now that it's connected to another room. You don't necessarily have to reset it. Try these steps first:
1. **Find the new IP address**: Use a device connected to your Wi-Fi and look up the connected devices list in your router's admin page. It should show the new IP address of your access point.
2. **Use the new IP address**: Enter this new IP address in your web browser to log in to your access point.
3. **Use APLOGIN.NET**: Sometimes, accessing it by typing "aplogin.net" in your browser's address bar can still work.
If these steps donât work, you might need to reset the access point to its factory settings and set it up again.đ
