paloma1
Mar 11, 2020Follower
unable to Netgear AC1200 to xfinitywifi hotspot
Hi, I subscribe to xfinity. I can login to xfinitywifi hotspot from anywhere which is great. I'm using the Netgear AC1200 but it will not connect to the xfinitywifi from the location I need it. Th...
schumaku
Mar 12, 2020Guru - Experienced User
paloma1 wrote:I subscribe to xfinity. I can login to xfinitywifi hotspot from anywhere which is great. I'm using the Netgear AC1200 but it will not connect to the xfinitywifi from the location I need it.
Knowing nothing about Xfinity WiFi (and far away from any Xfinity WiFi hotspot in Switzerland), I've done some reading on http://wifi.xfinity.com/connect-devices.php
In my understanding there are (or can be) two different SSID (network names) serving Xfinity WiFi hotspot:
1. xfinitywifi - this wireless requires requires an authentication using a username and password to associate, the security credentials are exchanged automatically between the WiFi client and the access point. There is no preshared key as common, much more this similar to business class wireless. Associating any kind of WiFi extender is typically impossible, because of a) extenders don't support business WiFi supplicants, and b) even if there would be a supplicant, the security details are not available to connect to the extender-served xfinitywifi network.
2. XFINITY - this is a non-secure (non-encrypted) network. Extending this should be possible. All the WiFi clients connected then to the extended network however needs to authenticate in the Xfinity WiFi captive portal.
-Kurt.
