adamnb
Apr 05, 2019Aspirant
Unable to set up my Wireless Extender to use the same SSID as my router
Hi all
I am unable to set up my WN3000RP Wireless Extender to use the same SSID as my router.
I connect the two using the WPS functions. Then when I go to http://www.mywifiext.net and try...
Christian_R
Apr 11, 2019NETGEAR Employee Retired
Hi adamnb - Please refer to page 16 of the user manual:
http://www.downloads.netgear.com/files/GDC/WN3000RP/WN3000RP_UM_1Feb13.pdf
~Christian
- adamnbApr 11, 2019Aspirant
Hi Christian
This isn't a solution, unfortunately.
I'm effectively trying to clone my router SSID. When I set the new SSID on the NetGear device as the same as my router, I'm unable to connect to the "newly named" network as it does not appear alongside my original network (as they have the same name) and I am told "You are not connected to your extender's WiFi network."
This means the process is incomplete and I have to start all over again.
