Chesterfield916
Jul 09, 2022Initiate
Universal WiFi Range Extender WN2000RPTv2 Working but cannot access to change password
I have a range extender which is successfully connected to my router via wifi using wps. I am presently connected to the extender with a cable and have access to a network. What I can't do is...
What happens when you factory reset?
After you reset, follow the installation assistant and NOT wps.
- Chesterfield916Jul 09, 2022Initiate
Huge thanks. I've tried the factory reset but each time WPS came on and connected.
Decided to try one last time but powered off router and extender first, can't believe I haven't reset the router.
Powered on router.
Powered on extended.
Accessed from laptop selected extender network and it took me through the set up and is now working!
Many thanks ... Wimbledon womens final has now finished though! This is what I was wanting to watch when I couldn't connect!
đ
