Octane302
Nov 12, 2021Aspirant
Unplugged my extender and im not longer able to connect to 5ghz network
I setup my extender i used in a dorm to connect to my new network but after it had a worse signal i decided not to use it. Now when i try to connnect to the 5ghz network it says it cant. I try connec...
Nov 12, 2021Guru - Experienced User
I'm a bit confused so just asking for clarity.
You put you setup the exetnder but had worse signal so you decided not to use it.
did you then reinstall it?
Or what 5ghz network are you connecting to?
Or did you move and are connecting it to a new setup?
Whats actually going on and what router are you connecting it to?
