Octane302
Nov 12, 2021Aspirant
Unplugged my extender and im not longer able to connect to 5ghz network
I setup my extender i used in a dorm to connect to my new network but after it had a worse signal i decided not to use it. Now when i try to connnect to the 5ghz network it says it cant. I try connec...
Octane302
Im no longer using the extender and im trying to return back to my original router network.The 5ghz is directly from the router. I just moved and its another wifi router so i set it up for the new router and didnt work so i went back to using only the router and i cant connect to the original 5ghz network
Nov 12, 2021Guru - Experienced User
whats your old router?
Why do you think the extender is impacting your device if the extender is off?
- Octane302Nov 12, 2021Aspirant
Its a c6250. The extender was plugged in and didnt improve the connection so i removed it. Now going back to the regular signal i cant connect to the 5ghz
- plemansNov 13, 2021Guru - Experienced User
what error does it give you?
Have you tried hardwiring into the c6250 to check its ssid/password?
