Barney7
Aug 01, 2020Aspirant
Unstable Ethernet connection on EX8000 extender
The extender is connected over WiFi to the router. Ethernet connection from extender to the PC (no WiFi card on the PC). I keep having dropped internet connection for up to 30 seconds before reconnect...
Aug 02, 2020Guru - Experienced User
Maybe the RAX is switching the EX between bands. Try turning off band steering (for testing) on the RAX and assign the EX to one of the 5ghz bands.
See if that stays stable.
What modem are you using?
What firmware is on the RAX?
Firmware on the EX?
- Barney7Aug 02, 2020AspirantSmartConnect has been disabled all along..The EX is assigned to 5G-1.What modem are you using?Arris SB8200What firmware is on the RAX?V1.0.2.88Firmware on the EX?V1.0.1.206I noticed this post... not very promising..
- plemansAug 02, 2020Guru - Experienced User
anything else plugged into the sb8200?
Its got 2 ethernet ports but only 1 is usable for the average user.
Have you tried changing which 5ghz is used for the backhaul?
Or tried downgrading the firmware? (if you do, do it over a hardwired connection)
Only the router is connected to the SB8200 modem.
I'm only using one of the ports on the EX8000.
I have tried both 5G bands.
Downgrading the FW is a last resort. Not ready for that at this stage.
