Barney7
Aug 01, 2020Aspirant
Unstable Ethernet connection on EX8000 extender
The extender is connected over WiFi to the router. Ethernet connection from extender to the PC (no WiFi card on the PC). I keep having dropped internet connection for up to 30 seconds before reconnect...
Barney7
Aug 02, 2020Aspirant
SmartConnect has been disabled all along..
The EX is assigned to 5G-1.
What modem are you using?
Arris SB8200
What firmware is on the RAX?
V1.0.2.88
Firmware on the EX?
V1.0.1.206
I noticed this post... not very promising..
Aug 02, 2020Guru - Experienced User
anything else plugged into the sb8200?
Its got 2 ethernet ports but only 1 is usable for the average user.
Have you tried changing which 5ghz is used for the backhaul?
Or tried downgrading the firmware? (if you do, do it over a hardwired connection)
- Barney7Aug 02, 2020Aspirant
Only the router is connected to the SB8200 modem.
I'm only using one of the ports on the EX8000.
I have tried both 5G bands.
Downgrading the FW is a last resort. Not ready for that at this stage.
