btberlin
Dec 02, 2021Follower
upgrading firmware on EX7000 Firmware Version: V1.0.1.90_1.0 gets stuck at DOWNLOADING AND UPDATING
rebooted extender EX7000 Firmware Version: V1.0.1.90_1.0 On management page selected update firmware. Starts, but gets stuck at downloading and updating language tables. Need help with firmware up...
Dec 02, 2021Guru - Experienced User
What browser are you using? Try a different browser? MS Edge or Firefox?
Netgear has set up a community forum specifically for the WiFi Extender products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
Dec 03, 2021Guru - Experienced User
Are you manually updating or using the automatic install setup?
You can try manually doing it.
https://www.netgear.com/support/product/EX7000.aspx
