btberlin
Dec 02, 2021Follower
upgrading firmware on EX7000 Firmware Version: V1.0.1.90_1.0 gets stuck at DOWNLOADING AND UPDATING
rebooted extender EX7000 Firmware Version: V1.0.1.90_1.0 On management page selected update firmware. Starts, but gets stuck at downloading and updating language tables. Need help with firmware up...
Dec 02, 2021Guru - Experienced User
What browser are you using? Try a different browser? MS Edge or Firefox?
Netgear has set up a community forum specifically for the WiFi Extender products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
jdguestsr
Mar 12, 2022Aspirant
Has this been resolved? I am trying to update from V1.0.1.90_1.0.156 to 1.0.1.106_1.0.190. Online update hangs on downloading and updating language table, manual upload fails with "firmware upgrade failed. Please check your file" error. This is with both Firefox and Edge browsers, and I have downloaded the firmware file several times (always the same size).
I am having issues with the router dropping connections, so I would like to get to the latest firmware to see if the issue is resolved.
Thanks,
