Gamer_merlin
Jan 30, 2022Guide
UPload speed is not the same.
I have a NIGHTHAWK router, RAX43 ( AX4200) just got it in decemeber, i am a twitch stream and for the whole week my upload speed has been give me problems., so when i do the test from the rout...
- Jan 30, 2022
If you hardwire a pc into the modem, what speeds do you get?
Are you testing your speeds on the router hardwired in?
Gamer_merlin
Jan 30, 2022Guide
The moderm is from optimum the cable company. "ARRIS " and the router says the firmware is update to day.
1. I did a factroy reset, already it did not work.
2. also the speed when i did from the wifi also show it slow.
3. only the netgear app, test show the connect is fast.
Jan 30, 2022Guru - Experienced User
What arris is it?
And sometimes the auto-update doesn't function as it should.
so what actual version are you on?
- Gamer_merlinJan 30, 2022Guide
it's the cable company modem
the router frimware is :
Version V1.0.5.106
- plemansJan 30, 2022Guru - Experienced User
Gamer_merlin wrote:
it's the cable company modem -----Which one? Arris makes a ton of devices. Its model number will be on the label.
Version V1.0.5.106
Have you tried updating to a newer firmware version? You're a couple behind. You can manually update.
OK i will try
