Gamer_merlin
Jan 30, 2022Guide
UPload speed is not the same.
I have a NIGHTHAWK router, RAX43 ( AX4200) just got it in decemeber, i am a twitch stream and for the whole week my upload speed has been give me problems., so when i do the test from the rout...
- Jan 30, 2022
If you hardwire a pc into the modem, what speeds do you get?
Are you testing your speeds on the router hardwired in?
Jan 30, 2022Guru - Experienced User
Gamer_merlin wrote:
it's the cable company modem -----Which one? Arris makes a ton of devices. Its model number will be on the label.
the router frimware is :
Version V1.0.5.106
Have you tried updating to a newer firmware version? You're a couple behind. You can manually update.
Gamer_merlin
Jan 30, 2022Guide
OK i will try
- plemansJan 30, 2022Guru - Experienced User
What arris modem is it?
