Gamer_merlin
Jan 30, 2022Guide
UPload speed is not the same.
I have a NIGHTHAWK router, RAX43 ( AX4200) just got it in decemeber, i am a twitch stream and for the whole week my upload speed has been give me problems., so when i do the test from the rout...
- Jan 30, 2022
If you hardwire a pc into the modem, what speeds do you get?
Are you testing your speeds on the router hardwired in?
Jan 30, 2022Guru - Experienced User
Gamer_merlin
Jan 30, 2022Guide
ok. it show slow when connect to the modem , so i am assume it's the company i need to call right ?
thank you. thank you i was thinking it was my router
- plemansJan 30, 2022Guru - Experienced User
Yes, if you're getting the same speed directly wired to the modem, thats the bottleneck.
