retiredinpresco's avatar
Jul 02, 2019
Use of NETGEAR EX6100-100NAS AC750 with Netgear Nighthawk AC1900
I have a Netgear Nighthawk AC1900 hooked up to an ARRIS modem from my cable company (Cableone).  This covers  my house. My shop is about 50 ft from my garage and I have no signal there.   Can I use ...
  • retiredinpresco's avatar
    Jul 05, 2019
    OK, I got my Netgear AC750 EX6100-100NAS range extender today.   As I suspected I could not get the push button auto hookup to work.
    The wifi on my ARRIS TG862 modem/router (from my cable company) had been disabled and a Nighthawk AC1900 hooked to the ARRIS unit is being used to provide a stronger wifi signal.   Then I went to the website in the instruction booklet and after a couple of tries I WAS able to get the extender to hook up with my computer network using an ethernet cable.   I then plugged the unit into my garage and was able to capture a signal on the ext network in my shop.  It's only 1 bar, so not very strong but good enough for me to get e-mail out there and check out a website or two.
    I'm a happy camper tonight and this is a good way to get maybe 50 ft of additonal range.
