TexanInParis
Dec 03, 2016Aspirant
Use range extender with AirPrint?
Some time ago, I discovered that our cable modem's WiFi won't support AirPrint, so I've been using a D-Link WiFi device to provide that. I have a bit of a difficult setup because the cable comes int...
- Dec 14, 2016
I ended solving my problem by getting two Netgear PLP1200 powerline adapters. They provide lightning speed and haven't dropped the connection in the several weeks that I've had them. I don't think the range extender would have been as reliable or as easy to set up.
DarrenM
Dec 13, 2016Sr. NETGEAR Moderator
Hello TexanlnParis
Hopefully someone in the community has tested air print on the extenders to give your the answer I do not have a apple device to test this.
DarrenM
