TexanInParis's avatar
TexanInParis
Use range extender with AirPrint?
Some time ago, I discovered that our cable modem's WiFi won't support AirPrint, so I've been using a D-Link WiFi device to provide that.  I have a bit of a difficult setup because the cable comes int...
  • TexanInParis's avatar
    TexanInParis
    Dec 14, 2016
    I ended solving my problem by getting two Netgear PLP1200 powerline adapters.  They provide lightning speed and haven't dropped the connection in the several weeks that I've had them.  I don't think the range extender would have been as reliable or as easy to set up.
