dtm_81
Mar 19, 2013Aspirant
Using 2 wireless routers?
Hello, sorry to join the forums and then start by asking a question right away. I have been lurking for quite some time and I can't find anything that fits my question. I am in the process of buil...
Retired_Member
Mar 19, 2013Run several cables to both locations for now and check back when you're ready to buy something. Almost any netgear dual band router would work well. Setup is simple and the help menus actually are quite helpful.
You would be amazed how much the WiFi coverage has improved with the newer designs since the 3400. I wish I was able to steer you to a certain model but I can't at this time.:D
The longer you wait to buy the better off you'll be.
