dtm_81
Mar 19, 2013Aspirant
Using 2 wireless routers?
Hello, sorry to join the forums and then start by asking a question right away. I have been lurking for quite some time and I can't find anything that fits my question. I am in the process of buil...
jmizoguchi
Mar 19, 2013Virtuoso
Run entire house with CAT5e. CAT6 is optional for most but been NEW house I would use CAT6 entire house . Multiple outlet for CAT5e/6 should be done so that any loop or additional can be ready to go
If I where you design your base come out with patch panel and design so that your main router can sit.
I also get PoE capable AP and have PoE injector or PoE capable switch so that when you place AP with PoE capable, you do NOT need power outlet at all.
If you want something cool , look at open-mesh.com. It has more bells and whistle but you will like how you can setup easy , and able to monitor with cloud.
