nishant786
Jul 16, 2011Follower
using 2 wn3000rp repeaters in cascade
hi i have a large area to cover with no hope of cabling. there are multiple floors and this is my current setup. now the problem is the 1st repeater works fine and gives me internet access. ...
fordem
Jul 24, 2011Mentor
If I might expand on what Strider has posted - to make it absolutely clear - you lose 50% of your throughput per repeater - so if you have a 1 mbps DSL internet connection, after the first repeater that's a 512 kbps connection, and after the second, it's 256 kbps.
You do NOT, repeat NOT, really want to daisy-chain repeaters - an ethernet cable is less than 0.25" diameter. and can be unobtrusively run.
