nishant786
Jul 16, 2011Follower
using 2 wn3000rp repeaters in cascade
hi i have a large area to cover with no hope of cabling. there are multiple floors and this is my current setup. now the problem is the 1st repeater works fine and gives me internet access. ...
liquifusionv
Oct 23, 2012Aspirant
netgearcustomerVA wrote: Hello,
I've been working with the WN3000rp units for over a year now to extend our home WiFi network working the repeaters off a Amped 10000 unit connected to a TrendNet WAP Model TEW-673GRU. I found that as soon as I upgraded the Netgear units to the new firmware, they could not be cascaded.
The previous post on daisy chaining (cascade) the Netgear units (using the old firmware) explains there is a trade off in bandwidth which a post responder recommended putting another 'wired' router between the two Netgear units as a solution. I'd like to hear specifics from someone who has actually done that set up if anyone has and to know if that did the trick.
My other alternative is to add a bi-quad antenna to the TrendNet router and maybe an amp to boost the signal strength as a an alternative to cascading the routers. There is also an option of using the Asus RTN12 with different SSIDs for each of the Netgear units. Has anyone tried that?
Are you able to let us know how you was able to daisy chaining (cascade) the Netgear units? I tried downgrading the firmware to 1.0.0.12_1.0.12 but it didn't make a difference and I still had the problem of trying to daisy chain it (where the 2nd repeater wouldn't connect to internet), I've changed the firmware back to 1.0.1.18.
