skiedagain
May 08, 2013Aspirant
Using a DGN2200 for Fiber internet
When I bought my DGN2200 last year, one of the big reasons for choosing it was the Netgear statement that it was easy to upgrade to cable or fiber. Now I have fiber internet installed and everywhere I look people state that it cannot be used for fiber because it does not have a WAN port.
Did Netgear lie to me or is LAN port 1 also a WAN port as it is on the BOB Lite modem that I was forced to change to as well as several ADSL access points?
My desktops are running 3 or 4 times as fast as they were on ADSL, my laptops are running at half speed.
I want by DGN2200 back.
- jmizoguchiVirtuosoYou purchased a DSL buit-in router/gateway not knowing there is WAN ports.
You can NOT use DGN2000 as router with Fiber if you want to use it. Unless Fiber broadband modem has router function you will need to buy new router
ONLY DGN family that would have worked was DGND3700
http://www.downloads.netgear.com/files/GDC/DGND3700V2/DGND3700v2_6-p_cover+interiorNA_06Mar12.pdf
At this point just but standard wireless router - skiedagainAspirantYet they continue to advertise the DGN2200 as "easy conversion to cable or fibre".
I guess "easy" to them means throw your Netgear away and buy one from someone else.
The product specs on Netgear.com.au shows a WAN port on Ethernet port 1. It is not a gigabit ethernet port but then again, this is Australia, Fibre maxes out at 100Mbps and I only get 25MBbps (Nominal).
Any ideas? - jmizoguchiVirtuosoIt has to have WAN ports and not LAN port 1-4 for model with DSL built-in that support other broadband
There is multiple DGN2200
got to support.netgear.com and identify correct one. - shamsAspirantthe product is netgear dgn2200v4 and i want it to use with cable (rj45 connection) is it possible?
- jmizoguchiVirtuosoRead this thread already answered
- FairytailVirtuosoYou can use LAN port 4 as Internet port if you have a cable connection. Please check the page 14 of the manual as reference.
http://www.downloads.netgear.com/files/GDC/DGN2200V4/DGN2200v4_UM_26Mar13.pdf
