clfaye
Jan 09, 2021Initiate
Using an EX8000 as an Access Point with "Enable one wifi name"
Hi - I have a RAX80 and an EX8000. I have tried using the EX8000 as a wireless extender, but the connection was too unreliable. I now have the EX8000 connected via ethernet cable and it is operatin...
michaelkenward
Jan 10, 2021Guru - Experienced User
Visit the support pages:
Support | NETGEAR
Feed in your model number, EX8000, and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
Jan 12, 2021Guru - Experienced User
In access point mode, the EX8000 doesn't have the one wifi feature because its a seperate access point, its not running in mesh. it won't work as a mesh device.
It only functions as a mesh when ran in extender mode.
You can set it with the same ssid as the router but devices won't roam like a mesh device. They'll be sticky and tend to stay connected to either the router or extender.
