Madura
Jan 03, 2020Aspirant
Using an X6S with LAN
I am trying to connect a seperate builidng in which I have run a cable out from D-Link router in the house. Can I use the Netgear Nighthawk X6S with the cable to extend my network to my workshop? If ...
Jan 03, 2020Guru - Experienced User
Yes, you can do that. Set the EX8000 in AP mode (only way to work hardwired) and follow the standard setup for AP mode.
How far was the run?
- MaduraJan 04, 2020Aspirant
Thanks. The run is 300 feet. The shop is a steel builiding with little to no radio signal inside (no FM radio, no WiFi and no cell phone coverage).
- plemansJan 04, 2020Guru - Experienced User
300ft. Ouch. The rough limit for ethernet runs is 90-100 meters. And thats with a Cat6 line.
https://www.showmecables.com/blog/post/cable-distance-limits-data
You'll want to do whatever you can to possibly reduce that distance as much a possible.
