nkdat63's avatar
nkdat63
Using EAX80 as a satellite for MR80 Mesh system with Daisy chain.
I have just upgraded my wifi system to the MK83 Mesh from the EAX80. But I don't want to get rid of the good EAX80 because the solid signal it brings to my devices. However, my issue is about Homekits devices, whenever I set up the EAX80 as an Access Point router with the same SSID to the MK83 Mesh, my Homekits stops working.
Please advise!
  • plemans's avatar
    You're running it in access point mode?
    Does it work fine if you leave it in extender mode (not hardwired in)?
    • nkdat63's avatar
      nkdat63
      Yes i ran it with wired as an access point using the same SSIDs and password with my Mesh system and it stops my Homekit devices. I wired it directly because I wanted a good speed in every room. I'll definitely try the extender mode today when I got home from work. My question is that could the extender mode work when it is wired?
      • plemans's avatar
        No. If its in extender mode, it shouldn't be hardwired back to the main router. That's only in access point mode.
        If you left it in access point mode, does it work with a different ssid?
        Also, what modem/gateway is the MK system connected to?
        Firmware on the MK system and the EAX80?
