hcornea
Aug 14, 2019Star
Using EX7700 Wired in Mesh Topology
We have a house which is an extended L shape, and I need to extend Wifi to one far end of the house. Current Network Topology R8000 (router) ----->> Ex7700 (wifi, extender mode) one direct...
- Aug 21, 2019
Hi hcornea - As you mentioned, the extender will need to be wired and in access point mode. If you set the SSID the same as the main host then the mesh can work correctly.
~Christian
Christian_R
Aug 21, 2019NETGEAR Employee Retired
~Christian
