vmlopez
Jun 19, 2023Aspirant
Using my Wifi Extender with ethernet connection to my smart TV
Has anyone experienced this problem ? I currently have a Samsung Smart TV and its currently connected to the Internet using the Wifi Extender with ethernet. When I'm on PC and checking my wireles...
- Jun 20, 2023
Thanks...I sleep fine..đ
michaelkenward
Jun 19, 2023Guru - Experienced User
vmlopez wrote:
How do I go about making sure that this connection is secure ??
What tells you that the connection isn't secure?
What does the anonymous smart TV's setup routine say about wifi security?
When it comes to wifi security, this is more in the hands of the main router than your EX6100v2 extender.
schumaku
Michael is perfectly right: For whatever reason, the AP of this extender (just duplicating the main router WiFi network name AND the security is not configured for WPA2-PSK or the like.
- vmlopezJun 20, 2023Aspirant
That isn't good...
- michaelkenwardJun 20, 2023Guru - Experienced UserIt's fine. You are protected by the router.
Try a bit more research if it keeps you awake at night.- vmlopezJun 20, 2023Aspirant
- schumakuJun 20, 2023Guru - Experienced User
What primary device does provide Wi-Fi for this network? Start from there. Define a secured Wi-Fi with WPA2-PSK to start with. And re-configure the extender to access that now secured network.
