oklord
Jul 11, 2020Follower
Using Netgear xtender to create wifi so ipad can connect to Windows 10 laptop w/out Internet
Good day! I'm trying to use a Netgear WN3000RP WIFI xtender to broadcast a SIDD so my Windows 10 laptop and ipad can connect to the WIFI allowing me to use an app on the ipad that controls a present...
Jul 11, 2020Guru - Experienced User
The extender wouldn't be the tool.
You'd want something with a dhcp server like a router.
If you're just using it for presentations and don't need internet, an old router might suffice. Or even a small travel router.
have you tried that?
You could even test it out at home with your home router by simply disconnecting it from your isp connection.
