jamieslack2000
May 05, 2021Tutor
Using Nighthawk X6 in AP mode configuration questions
Hello, I have some simple questions which i'm not sure about. So a bit of background. I have two Nighthawk X6 AC3200. One i am using downstairs as my router and the other i am using upstairs as my AP...
- May 05, 2021
Problem is that the R8000 aren't mesh devices. so they dont' have the smart roaming built in like the Orbi or Nighthawk MK series.
so devices will be "sticky". Meaning they'll tend to stay connected to the device they first connected to until the signal is close to unusable.
Even netgears "mesh" extenders only function as mesh in extender mode, not in access point mode.
So if you want to make sure the devices are connecting to the correct router, I'd change the names.
Otherwise you can leave them as they are and when devices aren't switching, just disconnect/reconnect the device and they should connect to the stronger signal.
Its why we tend to push Orbi or the MK series for people needing access points/satellites. Its simpler and devices roam more seamless.
In access point mode, you do want them on seperate channels so they aren't interfering with each other.
May 05, 2021Guru - Experienced User
- jamieslack2000May 05, 2021Tutor
Thank you for the detailed response i thought that maybe was the issue! Quick further question, on my AP i have it set to Smart Connect which requires the AP to have the same SSID as the router. Would you advise turning that off to change the SSID or to keep smart connect on and deal with the device connecting to the wrong device?
- plemansMay 05, 2021Guru - Experienced User
Smart connect doesn't require the 2x R8000's to have the same ssid for each other.
Just the same ssid for the 2.4ghz/5ghz band. And then it steers devices between them.
You should be able to leave it enabled to use the band steering and just change the one ssid.
when changing the SSID on my access point to HomeNetwork-UP i get the following error (provided on the screenshot)
