a_user
Jun 08, 2008Novice
Using WG602 in repeater mode...
Hi all,
I recently bought a wireless access point (NetGear WG602 v4) to increase the range of my network but I've been unable to set it up correctly. My network involves a wireless, Linksys router (WAG200G) which doubles as an ADSL modem and connects to my ISP. The PCs in the network use wireless, Netgear, network cards (WG111) to connect to the router and the Internet.
Thus far, I've only changed the operating mode of the WAP so that it's in "repeating mode" and have registered the MAC address of the router. The WAP sees the router but when I connect to the WAP's network, I can't communicate with the router.
Any help would be greatly appreciated.
- n_spect_rAspirantDid not answer either question. More confused.
- jmizoguchiVirtuosoRun cat5 wil your best choice .....
- jmizoguchiVirtuososince V7 can repeat and if you can to run cables then you have little options
use AP with external antenna both end with external antenna cable - n_spect_rAspirantThis did not answer either question, although I suppose in a round about way you said it is impossible to repeat with the current router. I think I'll go to Belkin and see if they are any more helpful, this forum certainly is not.
- n_spect_rAspirantThe issue is now moot although I seriously doubt that you will post this for others to see. Thankful to the Linux community for the dd-wrt firmware.
Flashed the WG602 and it is doing exactly what I want it to do, repeating the signal from the WG614V7. So it actually is possible, just not with the stock equipment. Although you were not helpful directly, your arrogance prompted me to keep looking, so for that I am thankful. - jmizoguchiVirtuosoWhatever
Netgear forum does not support third party firmware
Good luck
