Retired_Member
Oct 31, 2016Using wifi extender to feed signal to another building via ethernet connection?
Hi, I have a detached garage, and I'd like to hook up internet access there. The previous owner had ethernet lines installed between the house and the garage. Unfortunately, my internet is coming...
TheEther
Nov 02, 2016Guru
If the Ethernet jack in the house is connected to the garage then, yes, this would work. But are you sure the connection exists? How did the previous owner run the wiring?
