Dreamcazman
Apr 26, 2023Guide
Utilizing an old router as a Wifi extender
Hi all, I recently upgraded our main router with a Nighthawk XR1000 from an R7000. We have an Android streaming box in the lounge room at the other end of the house and for the most part it works ...
Apr 26, 2023Guru - Experienced User
You shouldn't really be needing to change anything with the XR1000 but with the R7000.
You want repeater/extender mode. Sadly, I think that feature was removed in one of the firmware versions. (not sure which one)
So you could either downgrade the version or experiment with 3rd party firmware (there's a ton for the r7000) to get that repeater/extender mode back.
Dreamcazman
Apr 27, 2023Guide
Thanks, the R7000 has a repeater mode but couldn't get it working with the XR1000. Also found out that apparently you have to disable any and all wifi security to get this working, which is not ideal for obvious reasons.
I ended up resorting to using the Tomato CFW and I was then able to set this up and seems to be working ok (still early days).
Unless someone can suggest a different solution using OFW, I'll leave it as-is.
