tvmaster
Nov 02, 2011Follower
utilizing WNR2000 v2 as an access point - can't change ip address
My addresses for my internal network are on the 192.168.0.xx address numbering system. The new netgear WNR2000 I just picked up is on the 192.168.1.1 address. I have plugged my laptop into the rou...
jmizoguchi
Nov 12, 2011Virtuoso
When you are changing the device IP then it will disconnect temporary from the interface
You need to either restart the pc so that you ge. The correct IP from the router or
ipconfig /release
ipconfig /renew
With this command should change to new IP that DHCP or setup static IP on PC with new ip schem and you can access back
ipconfig /release
ipconfig /renew
