edspyhill01
Jun 21, 2014Aspirant
Very Slow Wireless N750 Dual Band WNDR4300
The wireless speeds with this Netgear N750 Dual Band WNDR4300 are very slow. In fact, my Verizon cable modem wireless is faster.
Is there a document that details the best way to configure wireless on the N750 Dual Band WNDR4300?
Will running both the 2.4 and 5 Giga hertz channels slow things down?
Will running the guest channels slow down the wireless?
Finally, recommend a better router.
Ed
Ed
- jmizoguchiVirtuosoPosted in a wrong section which usually cause less reply or seen
Forum has specific section for your router model
http://forum1.netgear.com/forumdisplay.php?f=144
Always test the speed with computers with ethernet to the router and check the speed. If results are good then you signal issues in your surrounding etc. - edspyhill01AspirantThank you. I think the firmware level I'm in is the problem. Ed
