Retired_Member
Feb 06, 2012VMDG480 and WG602v4
Hi I have a VMDG480 as issued by the UK ISP Virgin which is the cable modem (not the ADSL), I also have a WG602v4. I want to bridge/repeat the signal wirelessly. I've seen this, which is exactly ...
Retired_Member
May 30, 2014Howdy,
Ok so it's take just a little time to try this out. Life gets in the way, often.
It's all working quite happily. The only thing I can't seem to do - which I appreciate is not your issue, but mine - is get my iPhone to auto-switch between the two units.
Any thoughts?
Thanks,
Adam.
Any thoughts?
Thanks,
Adam.
