Verrier57
Jan 19, 2022Guide
Voyant client clignote sur repeteur AX1800 EAX15
Bonjour, le voyant client n'est pas stable. Il passe de façon aléatoire de vert à orange. Quelle peut être la raison ?
Jan 19, 2022Guru - Experienced User
which light? there's several LED's on it and each mean something different.
the manual goes over what they mean.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
- Verrier57Jan 19, 2022Guide
It's the Client Link LED. Sometimes green, sometimes Orange.
- plemansJan 19, 2022Guru - Experienced User
the client link led tells the strength of the connected phone/tablet/pc/laptop.
The client link led is going to vary because devices move around. so sometimes the device connected will be closer and have a stronger connection versus other times its further away so a weaker connection.
OK Thank you. It means that if there are 5 ou 6 connected devices at home, as long as one of them is too far from the AX1800, the client link led turns orange. That's right ?
