Michael79
Jan 18, 2012Novice
VPN connection issues on GR614 v9
Hello experts I have to admit that I know close to nothing about networks/routers etc (although I have been working in IT for past decade) so please go easy on me:) I have been with Virgin Media...
jmizoguchi
Jan 18, 2012Virtuoso
The only DMZ setting I can find is "Default DMZ Server" where I need to assign IP. First of all my internet provider does not supply fixed IP (nor my customer requires it in order for VPN connection to work). Will your suggestion regarding DMZ still hold then?
you assign IP which device behind the router which needs DMZ .
Also, according to documentation specifying a Default DMZ Server can pose a security risk so I am not sure if I should go ahead with that.
one way to test regardless of make it's pc unsafe but any third party firewall on pc can protect that
