ZeroG
Oct 13, 2011Novice
WAG102 AP Mode slow connection
Hey I do have two WAG102 Routers, which work as Accespoints, to conect two floors. I also connect my laptop to this Routers wireless. My problem is, that when both routers run, my connection spee...
jmizoguchi
Oct 13, 2011Virtuoso
you can do point to point and may able to use higher encryption
on repeat and point to point usually proafe AP device can handle better encryption. you need to security standing point to but should be okay
