kiaville's avatar
kiaville
wall plug range extenders
Hi, I read on Netgear that they recommend specific extenders for specific routers. What extender goes with the N750 WNDR4300 router?
  • Hello kiavulle
    The Wn3500RP should work fine for you.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Kiaville
    You may want to look at wn1000rp to the wn3500rp since you have a wireless N router.
    DarrenM
    • kiaville's avatar
      kiaville
      Darren, What do you think of this one?   NETGEAR AC750 WiFi Range Extender (EX3700-100NAS)    I like the WN3500RP but I like the external antennas on this one.
  • DarrenM's avatar
    DarrenM
    Hello kiavulle
    DarrenM
